Re: Problem using toroid
  • Re: Problem using toroid
    Hi Peter
    I think that is the ringing you are seeing, and the other background
    noise might be helped with screening the toroid with aluminium foil?
    dont let it get through the centre of the toroid or it will make a
    shorted turn.
    Cheers
    John
    Cavalier Electronics
    L'Agulhas
    South Africa
    Hi John,
    thanks for your answer.
    I just looked to my recordings to examine the frequency, it has
    been about 750Hz. This is rather 1/3 of the
    expected proton frequency!
    The expected 2075 Hz was not to see on the scope. So I guess the
    water inside the toroid isnt enough magnetized.
    I'm rather sure of this because I can hear a noise coming from the
    amplifier and filter which sounds like
    a starting, a "pinging" oszillator at about 2khz and interferes
    with any other signal (may be the proton signal). Its interesting
    that this interference is allways there (without charging the
    coil!) and varies in frequency (maybe 2-3 Hz) without any period,
    its like a chaotic change. Maybe this comes from the geomagnetic
    field. I have to do some more experiments on the weekend.
    Greatings to South Africa from Germany
    Peter (DG4EK, JO30KG)
