Re: Problem using toroid
  • Re: Problem using toroid
    Another option to prevent ringing, might be to switch off the
    polarising current slowly - say 100mS which is 75 cycles of your
    ringing tone, but a small percentage wasted of the couple of seconds
    expected detection time.......
    If you are using a transistor to switch the current, you could
    experiment with an electrolytic cap on its base cct...
    John
    Cavalier Electronics
    L'Agulhas
    South Africa
    I just looked to my recordings to examine the frequency, it has
    been about 750Hz. This is rather 1/3 of the
    expected proton frequency!
    The expected 2075 Hz was not to see on the scope. So I guess the
    water inside the toroid isnt enough magnetized.
    I'm rather sure of this because I can hear a noise coming from the
    amplifier and filter which sounds like
    a starting, a "pinging" oszillator at about 2khz and interferes
    with any other signal (may be the proton signal). Its interesting
    that this interference is allways there (without charging the
    coil!) and varies in frequency (maybe 2-3 Hz) without any period,
    its like a chaotic change. Maybe this comes from the geomagnetic
    field. I have to do some more experiments on the weekend.
