Finding lost/abandoned water wells
  • Finding lost/abandoned water wells
    Most transmitters operate in the VLF range with extremely low power levels, almost non-existant. This makes them FCC-legal.
    But regardless of what frequencies or power levels you r device uses, the USPTO will not reject a patent claim because the use of that claim uses illegal or, more accurately, unlicensed bands. I could patent a novel new radio architecture even if it's use violated FCC regs. I just couldn't use it.
    Re: LRL Patent Questions and possible answers
    Carl : Begins to make one wonder why they, manufactures/vendors, don't at least copywrite the name and drawings of their units? After all copywrite does not laspe quickly like a pattent does. Unless I am wrong patents become open after 7 years, while copyrights are almost forever, also much cheaper, last I looked $10..00. Regards Marc And thanks for answering in the contsct it was meant.
      I'm seeking any info on using magnetometers to find lost or abandoned or buried
      steel cased water wells or drive point wells.
      Thank you
        Re: Finding lost/abandoned water wells
        ----- Original Message -----
        To:
        Sent: Wednesday, 14 March 2001 6:31
        Subject: Finding lost/abandoned water wells
        buried steel cased water wells or drive point wells.
        If you are looking for a cheap and easy approach I suggest that you try self
        potential first. All you need is a good quality meter that will read
        millivolts. Of course any magnetometer will do the job if you can hire or
        borrow one. Try any university with a geophysics department. They may have
        an old Jalander or something like that lying around.
        Roger Dewhurst,
        ROTORUA, N.Z.
        Politicians and babies nappies
        should be changed frequently,
        and for much the same reason.
          Thanks for the response. Finding lost wells gets a lot of attention in
          Minnesota. Any time you sell property with a well, you have to fill out a Well
          Disclosure Certificate and disclose if the well(s) are in-use, not in use or
          sealed by a licensed well contractor. Not in use wells are required to be
          sealed. Sellers who falsely disclose have a 6 year period where the buyer can
          sue the seller for cost of sealing and legal fees. If no well is disclosed
          then the county recorder rubber stamps that on your deed. We estimate there
          are about 1½ million wells in Minnesota.
          When property owners can't figure out where there wells are they are supposed
          to get the Well Contractors to help find them. But Well Contractors would
          rather drill new wells than find old ones so sometimes our well inspectors find
          the wells. Someday we may need to license "Well Finders", but for now to find
          lost wells our inspectors use mostly utility locators and backhoes.
          Last year another agency loaned us a "junk" magnetometer. A MP-3 Proton
          Magnetometer with VLF-3 VLF Electromagnetic Receiver and IGS-2 Integrated
          Geophysical System Control Console. At first the magnetometer was
          overwhelming. But other agency showed us what buttoms to push and we
          discovered a new world of well locating. The magnetometer is way more
          sensitive than the utility locators we have and it gets used all of the time.
          It finds and pinpoints buried wells, wells in demolition areas and at other
          difficult sites. I think it could pinpoint a deep buried well under a buried
          car body. We will probably have to give back the magnetometer someday. So
          what other tools /brands should we consider buying?
          We also have the problem of getting magnetometers to the well contractors.
          What types of magnetometers would be durable, convenient, reasonably affordable
          and definitlely more accurate than a utility locator.
          >>> [email protected] 03/13/01 11:41AM >>>
          The Proton Mag Forum
          To:
          Roger Dewhurst,
          ROTORUA, N.Z.
          __________________________________________________ ____________________
            . I think it could pinpoint a deep buried well under a buried car body
            This is fascinating stuff, but how does the mag detect the well? I have
            only been thinking of ferrous type targets..........
            John Smith
            lucky enough to live in Paradise, and work from home !
            see http://overburg.50megs.com
              Steel casing wells (drilled) give a good strong magnetic signal and with the
              magnetometer we borrowed the anomally is a distinct bullseye and the bullseye
              pattern shows right thru large amounts of overlying metal junk. Driven wells
              like well points are smaller in diameter so their anomally isn't as distinct.
              Dug wells often have metal anchoring for a windmill or other ferrous stuff.
              >>> [email protected] 03/14/01 12:20AM >>>
              John Smith
