Calibrating the Fluxgate Gradiometer
Hello Carl,
I finally got my detectors alligned. They are not perfect but there is very little variation. I can get it perfect with the set screws loose, but when I lock them down I always get a small amount of movement somewhere that I cannot seem to overcome. Maybe from pressure on the walls of the detector? Anyway I have it locked down with only a very small sign of misallignment.
I am having trouble understanding the calibration technique now.
In the literature provided with the kit from Fat Quarters, I have two different sets of calibration instructions. One of them says that with the instrument 60 degrees from horizontal with the high end pointing North, (doesn't say wich end to hold high, the adjustable detector end or the fixed detector end) rotate the gradiometer through 180 degrees, and the other says to "rotate the tube (head over heels) through 360 degrees".
Is it supposed to be rotated 180 or 360 degrees? (does it mater which end is 60 degrees higher?) and when rotating, is it turned like a driveshaft in a car turns, or like a baton twirler spins a baton, or like a helecopter blade spins? The "head over heels" clairfier confuses me more than it helps since the HEAD and the HEELS parts of the instrument have not been defined.
Jim Hatt
Hello Carl,
Jim Hatt
