Help with Fat Quarters Gradiometer
  • Help with Fat Quarters Gradiometer
    I am building a Fat Quarters Gradiometer that Carl designed.The PC Board has extra solder pads at the Digital Outputs of the SCL007 for interfacting to a computer.
    Question One; Do I solder from pads: 2, D7, D6, D5, D4, D3, D2, D1, DO to the nine pin seral port and is this the right order, starting at the top row on left side ?
    Question Two; what pads do I solder the two wires from the volt meter to ??
    Question three; On the lower right corner of PC Board shows pads foor a capacitor (C7**), is that part needed to be installed,I can not find any data on it..
    I thank all of you for all the data you talk about here, it is great. Thank you
    Dan
