hi!,
am wondering if i can wound my own sensor (solenoidal/toroidal) instead of the Fluxgate Sensor attached to the flux mag electronic assembly? i heard the flux sensor can detect at a max depth of 9 feet?
i want to have at least a light indicator tell me as to which of the two flux sensors is getting the signal. how and what to do with the sign bit. am planning to attach an extension PVC pipe on the upper flux sensor. inside this pipe is a metal which can be pulled up and down thereby giving me an estimated depth of the metal object under the ground by measuring the distance between the upper flux sensor and the metal in the extension pipe when the lower light indicator will light up. get my point?
