Gradiometer query - Speake SCL007
    Re: Fluxgate mag
    Expect that when I move sensors far apart sensitivity will improve ?
    As towed array, sensors say 2-3 meters apart will not be a big problem.... I think..
    Regards, Jan
      Re: Fluxgate mag
      Regards, Jan
        Re: Fluxgate mag
        Regards, Jan
          Re: Fluxgate mag
            Re: Fluxgate mag
              Re: Fluxgate mag
                Re: Re: Question 4 the Group
                Thanks, these were two packages I was looking at. Sounds like I can eliminate one.
                - Carl
                  - Carl
                    - Carl
                      I am trying to constuct an FGM gradiometer using Speake SCL007 FGM's.
                      I have a sine wave output from the differential, but it flatlines for a range of values.
                      Does anyone have any ideas about the feedback pin or whether calibration is necessary for a gradiometer?
                      Thanks,
                      Fred
                        Re: Gradiometer query - Speake SCL007
                        Just to be clear are you making a gradiometer using the SCL007 custom chip or doing something else ? (the actual sensors are called FGM-3s). I think the SCL007 is a specially programmed PIC (the pinouts are the same), Speake and co give details of the way it calibrates the two sensors in their documentation. I don't know the relationship between the digital output of the chip and the size of the magnetic anomaly though - you could try emailing them, they've been very helpful answering my questions.
                        The feedback pin is connected to one end of an internal coil which is wound around the sensor with the other end being grounded. I don't think its used with the SCL007 chip though.
                        Nick
                          We gave up on the feedback pin and wound our own coil around the sensor to create an offset. Thanks for your help though.
                          Incidentally, the change in frequency was about 3 times more than we were expecting...haven't worked out why yet.
                          Fred
                            no worries ! you mentioned a sine wave differential in your first post, are you using your coil to equalise the sensor frequencies and then looking for beats ? I'm doing a few tests on my sensors at the moment to work out the best way to use them.
