Now that laptop computers with decent 'sound card' capabilities are becoming more available, I wonder if anyone out there has seen any software to process a proton precession mag’s precession audio signals using a PC program?
I am not talking about processing the RS-232 data from some overpriced comercial mag unit (using even more overpriced comercial software), but rather, using the PC's audio capture and processing capabilities to build a very high performance magnetometer at very, very low cost.
It would not be very difficult to fabricate a basic 'sensor head' with an built-in preamp and polarizing current switch, then connect it to the ‘mic-in’ or ‘line-in’ and let the PC software do the ‘heavy lifting’ when it comes to processing, filtering, and counting down the audio.
I know this will work because I have found several very nice (and freely available) audio spectrum analyzer programs. These programs were found on ‘amateur radio’ sites and are intended for weak signal RF work. These audio spectrum analyzer programs are able to display even very weak and noisy precession sounds due to the powerful signal processing available on a modern PC. What they don’t do right now is the automatic conversion from Hz to Nano-Teslas (23.48719622nT/Hz) to convert the approx 2kHz precession audio into a direct numeric readout of magnetic flux.
Using the ‘sound card’ A/D and raw processing power of a PC would allow a smaller simpler and lower power sensor design. One of the PC’s ports could even be used to gate the polarizing current, reducing the sensor head to a small quantity of water (or kerosene), a coil of wire (gated by a mosfet or reed relay current switch), and a very simple op-amp audio preamp.
We’re only talking about 5 bucks in parts and a little software here, which seems like a really neat idea, but I don’t want to ‘reinvent the wheel’ so if someone has already seen a PC ‘sound card’ based proton precession magnetometer data reduction program, I would appreciate it if you would post the link.
Steve B.
Steve B.
