Does anyone know what happened to Jim Koehler's magnetometer plans online? All the links that I find are broken.
Re: Jim Koehler's magnetometer plans
Andrew,
i mirrored jims site just in case something like that happened,here it is on my server.
http://68.205.111.66:81/promag.html
The IP# has changed for my web server jims plans can be found here:
http://68.205.199.169:81/promag.html
Jims Plans
This is NOT the site describing the Jim Koehler's mag but the differential mag of Dan Fountain. However, the one from Jim, currently out of reach, is a much more detailed document supported by a very good principle description. If anyone is interested, I have made a copy of his main documents in PDF. Send me an email and you will get a copy of what I got.
Willy
Dan has always had his own web site,i thought the one i mirrored on my site was Jim Koehler's mag,it sure looks alot different then Dans mag site,if its not Jims then whos is it?
Dan Fountains proton mag
It's neither Jim Koehler's, nor Dan Fountain's. I don't believe anyone has ever found out whose web site it is, as there is no name or email.
Jim Koehler pulled his mag design info off the web because he thought no one was interested. However, he has agreed to allow me to re-post it on Geotech. In fact, he wants to update some of the documents. I'll wait a couple of weeks, and get back with him.
--Carl
Willy !!!! Help me out !!!
Willy, can you send me a copy of Jim's Mag plans in .PDF format ??? My email address is [email protected] ...Thanks Steve
EPE Magnetometer
I've built and tested the EPE magnetometer. The only problem I had was the GPS input working correctly. I made a double sided circuit board (I do this stuff for a living) and I have 3 extra boards, if anyone is interested. The board is slightly different (the EPE one was single sided) but it works fine. If anyone is interested ($10 postpaid) let me know. JR
