Hi. Has anybody read the United States Patent No 6,496,005 B2? You can find it on Geotech under Magnetometers/Patent. I understand some of it, but do anybody have an answer to:
1. What is the function of the coil (#102)
2. Can this thing operate at earth mag. field?
3. The fixed transmission frequency w1 (#115)is supposed to be "clearly spaced" from the proton resonant frequence. How much is "clearly spaced"?
In my wiue this magnetometer, at least in part, works like an HF SSB (SingelSideBand) Tranceiver in the sence that you have a carrier frequency that is being modulated by another signal (The resonance freq.of the proton)and as a result producing the carrier and two signals that is +/- the proton frequency. Then you filter out one of the sidebands and the carrier and you are left with the SSB signal. The original proton frequency can be restord (demodulated) by adding the carrier once again as a beat frequency.
Am I right so far??
Am I right so far??
