Re: Jan
Larry,
It might come to a suprise to you, but I do make a big difference between you and Dell.
You can see that in the way I talk to you or to Dell.
Also have a look at de endings of my posts to you or to Dell.
If I signoff with "Best regards" then I mean that
If I signoff with just "Jan" then I do not mean "Best Regards" ... if you get my drift.
You believe in LRL, I do not.
This has nothing to do with Carls article because I never believed in LRL.
I have very often looked into Treasurenet LRL forum (and other forums) but rarely participated in any "wars" going on there.
I just read all these questions, answers and had a look at the links provided by some people.
The thing that struck me was that LRL believers could not or would not give any proof of their claims.
I have a very simple aproach to this.
If LRL works then I must have a higher "hit rate" then when I just chance it.
If I do not get a higher hit rate.... then what good is an LRL to me ?
Do you not find this a valid question?
The only thing I ask is .... If you think LRL improves your hit rate, then show it.
But nobody wants to do that.
Do you understand my "problem" ?
I tried to explain this all with my head/tails example.
I do believe there are many LRL who honestly believe their instruments work.
There are two things I can think of that might cause these people to believe that.
1) The Ideomotor response.
2) Forgetting all the times they did not find anything
Same happens with Horoscopes.
When a horoscope is correct once, people tend to remember that, but forget all those times that the horoscope was wrong.
After a while they are strong believers in Horoscopes... because it is "always" right.
This is my personal believe and has no sientific background... In case people might think I have gone Psycho analitical ;-)
The thing that got me a bit angry was the obvious scam with the VR-800
That got me in this discussion and for the first time in a not polite way... well second time to be honest, but that was not about LRL.
About my "Mooing".... better not, we have this horrible cowdisease over here at the moment and they might put me down... :-))
Best regards,
Jan
Larry,
Best regards,
Jan
