This is a solenoid coil calculator for PPM.
From the definition of the Voltage applied on each coil of the sensor and its dimension, it plots the variations of the expected signal magnitude, Current, SNR, Weight and inductance giving the optimized number of wire layers to be wound.
One would define a maximum weight as constraint and search for the best SNR with a reasonable current.
One could as well define a maximum current as constraint and search for the best SNR with a reasonable weight.
These procedures outputs a wire diameter and a number of layers to be wound.
