Epe pic magnetometer
Originally posted by Krzysztof View PostHi Epitopios.
The hex must be loaded to the CPU via the programmer.
This is an internal hex in the processor program, does what you want (at least should be).
Vy73 Chris
is it ok with the programme ???
Hi Epitopios.
These are from original source original supplies (EPE), I do not know different "hex".
Author said several years this on different forum unfortunately, that it does not remember with this programme details.
I will deliver you all my supplies on this subject.
I work on different family of processors and this hex to me does not fit - unpleasantly me.
I know men what this they made, they told OK.
I greet Christopher.
I received all your email and I thank you for all your help
i have to make some change on the PCB and after the help of a pc-friend I finally saw on the screen : EPE MAGNETOMETER and after that immediately COMPUTER TRIG , is that correct ???
so far so good ???
friendly , epitopios
Welcome Epitopios!
I gave an important speech BOLD
Looking at your assembler and found this:
WAITINGPC: clrf LOOP
call LCD1
bsf RSLINE,4
WAITPC2: movf LOOP,W
call WAITPC
call LCDOUT
incf LOOP,F
btfss LOOP,4
goto WAITPC2
call CLRLINE2
return
According to me, you have your PC attached in the WAITPC the loop, it displays the string.
;********* START OF MAIN PROGRAM ********
MAIN: btfss RECORD,1 ; is record switch on (low)
goto MAIN00 ; yes, so bypass check for download switch
btfsc PORTB,4 ; is PC switch on (high)?
goto CHECKPC ; yes, so wait for PC to ask for download
goto MAIN0 ; no, bypass look for PC handshake
CHECKPC: call WAITINGPC
When you turn on MAG is waiting to find the GPS satellites
Good luck.
My MAG already is talking with me but do not want to use the SD card logger.
The programmer must be patient, consistent and continuously learn.
Best Regards, Vy73!
Chris.
EPE magnetometer
Hello ,
I am interested to build this project too...but i"m having trouble finding the files.How is the outcome of the reading on the PC software...Is it clear?...Any bugs you found so far in the original EPE projectfiles?..
If you have any PCB,Parts List and so on i will be gratefull...
Reagards
[email protected]
Marius
Hi I'm looking to made EPE magnetometer, the 2003 version, I'll receive the componets in this day, I've already made the pcb, but I've the problem to understand how make probe or sensor staff. Somebady can help me?
ps: I bought some piece for made this kit and I can build two, if someone is interested for all component for a kit send me a private.
Robert,
I've removed this post because the PDF files violate Wimborne's copyright. Even though the PDFs reside on another web site, we still need to respect Wimborne's copyrights and not encourage violation by linking to them. Wimborne has been very generous in allowing me to post older articles on Geotech.
Thanks,
Carl
Code for Everyday Practical Electronics (EPE) Magazine - PIC Magnetometer for Metal Detectors and Archaeologists - July & August 2004
Enjoy!
Robert
Code for EPE PIC Magnetometer for Metal Detectors and Archaeologists - July & August 2004.zip
hi leto dear
please send me schematic and PCB & adjustment & manual for EPE magnetometer email:[email protected]
Hi mates,
I'm considering the possibility of to build this tool. Someone that built the EPE Mag, could to show the results of the field tests?
Would be much interesting, to know something about the real performances (deep with detailed references).
All the best, D.
Hi Damiafix.
The same sensors, the same real sensitivity.
With the digital approach to the PIC and LCD have the results you see and you can register. It remains to be programmed.
Ask around Geo and Epitopios, they did it.
Take your MAG for a walk, but slowly, it yields results.
Best regards Chris.
