Epe pic magnetometer
  • Yes, it works well. Thank you. Has anyone tried to display the 3D graph?
    • can someone please send me pcb schematic parts and files of magnetometer PLEASE??? AND WHAT DEPTH CAN THIS MAGNETOMETER GO 8 METER?
      • My EPE PIC Magnetometer works well. But there is a problem. The LCD module displays the reverse B and T sensor. Why? All connections have been checked and are fine. Thanks for your help!
        • In addition it is. If you replace the input pin of the IC 4013, 3 and 11, and the display, replace the values ​​for the TOP and BOTTOM sensor. No way to reconcile the BOTTOM sensor is down and that the display be left where the value is not provided to these values ​​are shown in the TOP.
          • Reverse the wires from sensors to pcb.
            • Then the value of TOP sensor is shown as BOTTOM.And vice versa.
              • BOTTOM sezor should be located closer to the ground. His values ​​loaded tube to be displayed on the display to the left, where, when the Test, a B / bottom /. Well, now the problem is that they do not show where it should be, but in a place where the values ​​of TOP / T / on the right. If you turn the wire, and turning to the values ​​and get nothing because now BOTTOM sensor goes up and display the value of the BOTTOM position, but he is not down, but at the top. Is that correct? I'm sorry to explain like plastic, my ignorance nice to explain. Thank you for your help. I hope that I will get the right answer.
                • If the signal from the BOTTOM sensor goes to pin 3, IC 4013, and it is displayed on the display where it belongs, the question is whether it really matter where that sensor is located and whether the results of the measurements will eventually be the same? or I do not understand something. Please Help!
                  • mine too
                    • Originally posted by sapica View Post
                      Hi. I did not check where is connected the sensor but at my mag when i put an ferrous object near to bottom sensor (this who is near to ground) then the bottom frequency changes. If the object is very big and near to bottom sensor then changes a little and the top frequency.
                      • Is it allowed to add video? I have to bring it to work as intended. Thank you for your patience.
                        • As i know no problem to add video if the size is inside the limits....
                          • kapios ama mporei na steilei pcb sch kai ta arxeia tou giati prospatho na vgalw akri kai den vgeni ...
                            • Originally posted by antonioknight View Post
                                i am sorry for mistake what i write was if somenone can give me pcb schematic for epe magnetometer please thank you
