Epe pic magnetometer
  • #61
    yes ican project for epe 877
    thank you
    • #62
      I think mr Epitopis have a working magnetometer and working dataloger.Buth problem is in recorded data format and represetation this data in some geo software..
      Regards too all!
      • #63
        dear friend Miki73
        Leto wrote in the previous page :
        Have this one.. works OK but not very suitable for logging carl's gradiometer.
        Thats why i am looking for data Logger for Carls gradiometer
        so , if someone can help us !!!!
        friendly epitopios
        • #64
          Magnetometer - Gradiometer
          who can help me please here to connect those two pcb ?????
          the gradiometer and datalogger
          there are some numbers on the box of datalogger and 8 pins on the pcb of gradiometer , which are the correct connections between them?????
          friendly epitopios
          • #65
            pleas up hex file for pic & part list
            thank you
            • #66
              Hi friends,
              Did I can find or detect gold and treasure under soil
              by Epe pic magnetometer ?
              Or Epe pic magnetometer only can detect iron
              and ferromagnetic metals ?
              Thanks...
              • #67
                Originally posted by zenit52 View Post
                Hi friends,
                Thanks...
                exactly 100%
                friendly epitopios
                • #68
                  Hi epitopios,
                  Thanks...
                  Thus the best choice to detect gold in 2-3 meter depth under the ground is only PI metal detector ??? yes?
                  what is your propose...?
                  • #69
                    Hi epitopios,
                    Thanks...
                    Hi zenit52
                    I am just a radioamateuer and very fresh here in this forum with so many guru in this hobby , i just find out that my gradiometer shows me from a distance of 20 - 30 burried things , then the next step is to find out what is underground , so its up to you what you use next , a good metal detector to find out the ferrows and non-ferrows metals ?
                    the next move is yours
                    * next days i will see the bionic machine of a friend
                    friendly epitopios
                    • #70
                      LC oscillator
                      The inductance changes because the coil is wound on a core with high permability. It`s inductance changes when influenced by ferromagnetic materials. Seems as if the sensor electronics is some kind of square wave LC oscillator.
                      • #71
                        Hello Olsteffe
                        Very close !
                        It seems that the sensor is a Armstrong oscillator ( thanks Ivica !), the coreform inside is a metal strip like vitrovac or metglas. ( both work )
                        If you look at Yahoo magnetometer group you can find more info !
                        There is a circuit that works !
                        Regards.
                        Ap
                        • #72
                          thank you
                          the gradiometer :
                          data logger:
                          friendly epitopios
                          • #73
                            data logger
                            friendly epitopios
                            • #74
                              Hello
                              I attached 8 Channel analog data logger Pcb in sprint layout
                              Erol
                              • #75
                                Hello Epitopios
                                Do you have the complete article? I can just find parts of part 1 and 2
                                Sincerely
                                olsteffe
