Epe pic magnetometer
  • Originally posted by damiafix View Post
    Hi Olsteffe,
    Do you think that the auto calibration of the SCL007 is better then the Epe? I've build a Gradiometer from the Carl's project; can I use it with the EPE?
    I'm thinking to start a EPE Magnetometer, but now I've the problem of the correct aligment of the two FGM-3 (I've start a 3d about, in this room, no replyes for now)!
    All the best, Damiafix.
    Hello damiafix
    it is no doubt that the autocalibration of SCL007 is better, it measures each sensors max and min value and calculates the sensor offset so they will respond in a similar fashion in earths magnetic field. It does not however correct for non linear sensor properties (most of the sensors are pretty linear so this is not the biggest problem). The problem is that it is not possible to interface with the epe magnetometer.
    You could try the EPE datalogger if you need logging capability. The free VISIT visualization software could be used for displaying your results.
    The problem with both the epe and scl gradiometer is that they are using period counting so you have to stand still for one second to get a stable reading at one spesific location then move on to your next reading. So if you are looking for small artifact and not shipwrecks take your time and the result will give good resolution ie 4 samples per meter should give good results.
    The epe magnetometer is however superior in capabilities with gps and that it takes separate readings there is opportunities for post processing of the data ie ignore differences higher or lower than preset value.
    I am working on teaching myself microcontroller programming hoping to modify the epe magnetometer with calibration routine and reciprocal frequency counting of the sensor output to obtain high resolution area sampling at walking pace.
    PS when aligning the sensors think of removing all metall ie credit cards metal frame glasses belt buckles eyelets in your shoes (ok dont take them out just put on some slippers)
    Regards olsteffe
    • Hi Olsteffe,
      many thanks for the clarifications, I understand perfectly; so when I'll finish the Carl's Gradiometer, and I'll have aligned correctly the two FGM-03 I'll start to build, the EPE Magnetometer (many thanks to ivconic for the docs). But at this moment I've serious problems with the aligment of the sensors. In my test, I've removed all metals and magnetic perturbations around the probe (I've tested it in mountain) but when I place the probe vertically to the ground, the VCO play sounds continually. It's very strange, I will check all the connections, but the tool seems to be sensible to the metals (but a low sensibility)!
      Look here:
      http://www.geotech1.com/forums/showthread.php?t=15863
      All the best, D.
      • pleas send full Epe pic magnetometer & data loger2 or (hex file) proje for me
        [email protected]
        best regards
        • Epe pic magnetometer
          I have made Epe pic magnetometer
          1- whats the distance between two sensors ?
          2-if it is possible , I am interesting about data loger2 or (hex file) project for me, I dont have the .hex (file) Please HELP !!!!
          [email protected]
          Friendly, epitopios
          • Originally posted by epitopios View Post
            [email protected]
            Friendly, epitopios
            i am still waiting for some help for hex.file
            friendly , epitopios
              Γεια σου Πανο.
              Δεν αφηνεις το Γραδιομετρο και να κοιταξεις να φτιαξεις το κυκλωματακι που σου εδωσα!!!!
              • The cicuits ate us like Julia!!!!
                Tι κύκλωμα για μολογάτε!!!
                  Γεια σου Πανο.
                  αφού το έχω βρε Γιώργο έτοιμο , γιατί να μην το δούμε και αυτο σε σύγκριση με το άλλο ??? περιμένω και άλλα 2 FGM-3
                  απλώς δεν το βλέπει το laptop γιατί του λείπει ενα .hex file
                  I just dont have a .hex file of his programme !!!
                  and I dont know if it works with windows 98 or windows XP ???
                  Takis , why you worry ???
                  • Hi Epitopios.
                    What is to Windows. Hex is the processor.
                    Is the hex that was what you got to find it.
                    Vy 73 Chris.
                    • Originally posted by Krzysztof View Post
                      Hi Epitopios.
                      Vy 73 Chris.
                      dear Krzysztof
                      yes , its missing an .hex file ,thats my problem
                      and if you know if this programme works with windows 98 or windows XP?
                      or both ?
                        Γεια σου Πανο.
                        Γιώργο , καλά που το είδα , λάθος ολοκληρωμένο μου είχαν στείλει
                        γι αυτό δεν είχα σήμα !!!!!
                        θα περιμένω το σωστό και θα σε ενημερώσω
                          Hi Epitopios.
                          Vy 73 Chris.
                          dear Krzysztof
                          I just received your 3 emails
                          i will work on them with a friiend who knows well the PC programmes
                          thank you and I appreciate a lot
                            I"ll try to call you at afternoom.
                            Who IC was wrong??? From Elektor or from Gradiometer????
                            • Originally posted by apogonos View Post
                              Kala ρε Julia εφυγες χωρις να περασεις απο το σπιτι η να παρεις ενα τηλ.
                              Γαιδουρι !!! (δεν θυμαμαι ποιος το ελεγε)
                              • Hi Epitopios.
                                The hex must be loaded to the CPU via the programmer.
                                This is an internal hex in the processor program, does what you want (at least should be).
                                Vy73 Chris
