Epe pic magnetometer
  • Hi mrkhrdr.
    See it at Circut Cellar.
    http://circuitcellar.com/25th-annive...820&height=420
    There is described Your idea. However, due to the large inductive coupling is a big influence on the coil DC.
    The trick is to maintain the point of working on the line side of the characteristics of B/H.
    In FGM3 this gives a current flowing through the primary coil.
    In the case of the perfect work on top of the bell curve B/H frequency changes due to changes in the magnetic field would be unnoticeable.
    Best regards Chris.
    • The link you are referring to is of a project by late Richard Wotiz that was published in Circuit Cellar 6/2006
      • ivconic What is the range sensor
ID:	336108 Click image for larger version
ID:	336109 Click image for larger version
ID:	336112 Click image for larger version
ID:	336113 Click image for larger version
            • There have been a couple of photo-attachments posted here and I don't know what they are. Makedonyah, you asked Ivconic for information about the probe on the chair. What is it? Did you get a reply from Ivconic?
              Orbit, you submitted some photos of the Predator3000. What is that? What are you trying to say by posting these? I tried Googling the Predator, and there it seems to be anything but some kind of magnetometer.
              I don't mean to complain, I just want to know what's happening. To be in the loop, as we say.
              Mark
              • Originally posted by makedonyalı View Post
                [ATTACH]23989[/ATTACH]
                about 50cm =70cm !
                • predator 3000 for the Softer Geosurveyor 2 ,and different precious metals and tunnels of iron objects !
                  • http://www.youtube.com/watch?v=w5Bu6uXterc
                    • can i use Geosurveyor 2 to download data from epe pic magnetometer?
                      predator 3000 is like epe pic magnetometer?
                      • predator 3000 magnetometer is , but not the same as epe pic ! so epe not know if it can to work with geosurveyor 2 !
                        • did you make predator 300 or buy it?
                          can you give schematic pcb hex etc?
                          • where can i download Geosurveyor 2 v2.3.2?
                              about 50cm =70cm !
                              Thanks orbit
                              • epe pıc hex does not work
                                epe magazine downloaded
                                have successful hex?
                                Or do you have running the device?
