Hi Willy, how much distance must you keep between the PPM and AC power lines? Thank you Willy.
Our system is designed with a powerful bandpass filtering and sensor tuning at around 2KHz and, moreover, its signal processing rejects all random noise from the environment. Thus, the AC power line are not too much disturbing.
I have already made some surveys along roads in the middle of my village with power lines going over or under without any disturbance.
The only influence is from DC power lines which generate a large magnetic field which then drastically changes and covers the much weaker earth magnetic field. This is the case from our electrical railway network which is powered in 8KV DC. It means that I can not go closer than a few hundred meters from a railway line.
Willy
Willy
