Sensor substitution
    Originally posted by SimonS View Post
    15.1.2017. I got note from his wife RIP!
    Sad to hear that!
    6-7 years ago i exchanged several emails with him.
    He was more than polite and highly professional person.
    God rest his soul!
      Hi to all
      Mr. Bill Speake is dead and now is problem where to buy this sensors. I try to make it, but there is simple no information. I try to measure coil resistence (FB). FGM3 frim 3.sensors I got 3. diferent result. Same with FGM-1. It look there is not same number of turns. I have no idea why.
      Have someone more information?
      BR Simon
      Sorry to hear that, may he rest in peace. I did ordered 2 sensors from him last December. Very nice person.
        Another Great taken by time. It gets us all in the end. Messed Up Deal.
          Hello all.
          The thread is a bit old, but may be ..
          About the speake sensor, does someone knows what kind of core is used inside ?
          soft iron ? Ferrite? Permalloy?
            Originally posted by Idefix View Post
            Hello all. The thread is a bit old, but may be .. About the speake sensor, does someone knows what kind of core is used inside ? soft iron ? Ferrite? Permalloy?
            I think permalloy 80...82 (Ni%) or amorphous alloy. I made permalloy using, but sensor gave a little range (50...80 kHz). Permalloy used 79 (Ni%), gtrip gauge 0x08 mm.
              Hi
              thanks for answering.
              What do you mean with "gtrip gauge 0x08 mm " ?
              I have made some runs on spice, to check the behaviour.
              I now need some info about the core, material used , and dimensions , like sheet core , or cylindrical core.
              the xray picture in the thread doesnt allow to learn about the shape of the core.
                Hi thanks for answering. What do you mean with "gtrip gauge 0x08 mm " ?
                thickness 0,08mm. I think need 0.02...0,05 mm. I do not know what kind of core there is.
                I have made some runs on spice, to check the behaviour. I now need some info about the core, material used , and dimensions , like sheet core , or cylindrical core. the xray picture in the thread doesnt allow to learn about the shape of the core.
                https://jpegbay.com/gallery/006775754-.html#1
                  I found the notes from my Speake sensor core. The alloy part measured 3mm wide x 40mm long and was sandwiched between thin fiberglass strips. If you find the correct alloy please post the information. I found that the anti-theft tag material ("Metglas") would not oscillate with the Speake circuit.
                    Thanks for the picture. Very useful, it clarifies the x ray picture .
                    About the core, if I understand, it is a cylindrical core of 3 mm, length 40 mm, wound with wire, and after, there is some fiberglass roll over, and,some alloy again ?
                    Is it exact?
                      The core is some kind of perma - alloy metal foil. Kolyay described as .08 mm thick. Assuming he is correct the core would measure 3 mm wide X 40mm long X 0.08mm thick. This foil is sandwiched between pcb material with the copper removed. All together with the foil and pcb strips it measures. 3 mm wide X 50 mm long by 1.5mm thick. Not round
                        OK. It is more clear .
                        The difficulty will to found some permalloy.
                        I have an old TV set ready to go to the garbage, I think that there is a sheet of permalloy around the cathodic tube. I will have a look.
                        I will post as soon as I have made something running.
                          Another source to check, some toroids are "tape wound" of permalloy foil. One might be able to crack open the outer shell and unravel the tape. I recall seeing one used in a GFI receptacle.
                            I have a spool of Metglas 2705M. It is 0.1 inch wide and 0.002 inch thick.
                            Data sheet:
                            https://metglas.com/wp-content/uploa...l-Bulletin.pdf
                            Not sure if this is a permalloy. If this will work I can send you a couple feet of it.
                              waltr, thanks a lot.
                              There is a manufacturer of amorphous metal tape/toroids in India (http://uaml.in/). I have requested them for some samples.
                              In case, I am not able to find anything, I will be grateful to use your generosity.
                              Thanks once again.
                                Data sheet:
                                I have a roll of Metglas also, that I purchased from Less Emf. The 2705M is supposedly the same material used in the anti-theft tags. I did alot of experiments. What I found was when used on the bench. It tested very sensitive in simple oscilator circuits. When ever I tried potting or laminating the metglas foil. The sensitivity would drop due to mechanical damping. Apparently it needs to be semi-free to vibrate. Maybe some kind of heat treating would cure this problem?
                                This video mentions the same about leaving it free to oscilate.
                                https://www.youtube.com/watch?v=dP84iJlQCDI
                                I have some Ultraperm 80 which is 80.3% nickel, 14.3% iron and 5.4% molybdenum. This is working in the Speake FGM-3 circuit.
                                I am still trying to work out the correct number of turns for the primary coil and feedback
                                Ultraperm 80 on ebay
                                https://www.ebay.com/itm/MuMetal-Ult...-/152045122881
