Overhauser Mag Information
  • Overhauser Mag Information
    A friend of mine is working on building a Overhauser Mag. Has anyone on here ever built one of these, and is there any freely available info about with schematics etc.?
    overhauser mag
    A tough thing to do...signalls levels are much higher then PPM, will need only a fiew hundered mW of pumping RF at cca 60 MHz, but big problem is free radical needed in NMR liquid, hard to get and chemically unstable, will decay in a fiew days...only GEM systems developed such radical that will last several years (as far as I know)...
    ms
      I think the sensors are going to be sourced in Russia, that overcomes the free radical problem.
        In that case
        I am more than hot about getting such a sensor to build Overhouser...Can you please give us more information where toget it? Electronics will not be such a problem...
          I guess this must be the place. I will check to see if this is correct.
          'The Laboratory of Quantum Magnetometry of Ural State Technical University (USTU-UPI) is the only designer of Overhauser sensor in Russia.'
          www.dpt.ustu.ru/labqmag/research.htm
          http://magnetometer.ur.ru/content/bl...n/0/9/lang,en/
            Is there no patent on the free radical fluid, from which we could learn?
            or are chem labs across the world not capable of producing such liquid?
              A friend of mine was working on one a few years ago. He found a free radical solution from Fisher Scientific. The RU site above had more details before. There were pictures of the sensors and other details. The sensors were about the size of a aluminum cola can. I have some notes which I will look for, in the mean time here is a good patent to start with.
              Mark
                I found this article which uses "Tempone". I believe that is what my friend was going to use. The same paper mentions using the "ppm" platform with RF circuits added. Which means you can use a proton mag as your base.
                Mark
                  sensor compound of overhauser mag.
                  I want to know the compound of sensors of overhauser mag. , and its concentration?
                    Thanks for the paper/patent.
                    Let me see what I can make out from these two.
                      I am very interesting in OVH mag.. Please help each other, more communicating.
                        Mr. Dong,
                        Maybe you could communicate what you know about the overhauser mag? So we can all share the information. Thanks
                          Mr. Altra,
                          First, the sensor's compound? and its concentration?
                          Second, what frequency and power of RF? its relationship with sensor's compound?
                            More info?
                            Is there any detailed technical descriptions on the Overhauser mag? Principle of operation, schematics, etc?
                            Thanks,
                            BT
