Hi guys,
I'm checking the gradiometer's connections and the integrity of the various IC's.
I've noted that sometime the tension on the DAC, between GND and pin 16, is also 4.5 volts. I think that it's damaged; from the AD557 datasheet I read that the tension on the Vcout should to be max 2.5volts.
What do you think?
About the SCL007, someone could tell me the reference tensions? I wish to check anything!
Cheers, D.
What do you think?
Cheers, D.
