Have done some reading about ppm fluids. Seems most use
water or an alcohol (ethanol, methanol).
If I understand (please correct me as needed
) the ppm
detects the protons in hydrogen as they spin out of
alignment.
So it seems that if the fluid has relatively more H it will
generate a stronger signal. With this in mind, I spent a few
minutes with wikipedia and a spreadsheet (OpenOfficeCalc)
and found the following:
Six "fluids" are listed with their formulas, densities, and % of
H relative to water. I used molecular weights and grams/mol
to derive the result.
So, given the potential for a 20% gain in signal strength,
has anyone used paraffin (wax) as a working fluid? If not,
why? It seems that because it is "solid" at room temps
it would be quite easy to work with.
regards,
thom
alignment.
Code:
Substance Formula Density %H Water H2O 1.00 100.0 Propane C3H8 0.58 95.4 Butane C4H10 0.60 92.9 Methanol CH4O 0.79 88.4 Ethanol C2H6O 0.79 92.2 Paraffin C25H52 0.93 123.6
regards,
thom
