Because gradiometers measure the change in magnetic field and as such they are sensitive to ferromagnetic objects. If I would create fast changing magnetic field with electromagnet shouldn't I be able to use gradiometers to detect the induced magnetic field even for para- and diamagnetic materials. Basically para- and diamagnetic materials (e.g. stainless steel) should have higher conductivity than even mineral rich rocks so I should be able to see them?
Practically the electromagnets probably had to be quite big so I'm not sure if it would be feasible to carry them and the powering unit around.
