EPE Magnetometer Program Problem
  • EPE Magnetometer Program Problem
    Hi.
    I try to load the progrmam Magnetometer of the project EPE Magnetometer 2004 into the computer.
    It return a Run time error "372". It writes::
    ""Failed to load control EPEserial from EPESERALIO.OCX. Your version of EPESERALIO.OCX maybe outdated. Make sure you are using the version of the control that was provided with your aplication.""
    Any idea??
    Hi Geo.
    See the final part of description the OCX.
    It seems, that only will suffice MAGGY710.HEX
    I can You send on PM possessed materials.
    Best regards Chris.
      Hi Chris.
      Really i did not understand anything.
      Can you help me more????
        Hi Geo.
        It seems, that OCX serves to receipt of broadcast Rx through joint COM only.
        It had to serve to measurement of resistivity of the ground. It writes so there.
        Write what you want to get.
        You in materials on PM have the addresses with different forum and ways of their solutions.
        Best regards Chris.
          Hi Chris.
          I download the file that you post to me and i have the same problem.
          Is it necesary to connect the magnetometer to the computer before to run the program???
