Re: DALTON MAGNETOMETERS & MAGNETOMETER FLUID
  • Re: DALTON MAGNETOMETERS & MAGNETOMETER FLUID
    go back (no emotion) and reread all messages
    involved.is your conclutions the same ?
    Re: Carl's bad manners
      I don't know much about dalton's mag other than it appears to be a
      pretty basic unit. When I was first interested in buying a mag, I
      was looking into land based units. I too ordered Dalton's info pak
      and book. I found the book a bit difficult to understand mostly
      because of his writing style which I believe is suppose to include
      some dry humor. I didn't respond to it well and don't really care
      for it. I then got on some of the treasure forums and asked other's
      about their opinions of his unit and heard nothing good about it. I
      do have a book on Padre Island treasure hunting where his unit is
      recommended mainly because of the low cost though. Fortunately
      before I had to make a decision I came across a heck of a deal on a
      Geometrics G-856 proton mag and bought it. I agree with Dan, do a
      lot of checking around before turning loose of the cash. From what I
      can see, his unit looks to be somewhere close to the equivalent to
      Phil Barnes' kit which can be had for a lot less. In comparison to
      JWFishers unit that Dan is talking about it appears Dalton's mag is
      a dual differential unit which is good compared to the single sensor
      the JWFishers unit employs, however the Fishers unit has other
      features I would rather have over Dalton's unit. Fisher's is a
      pretty common mag where like Pat, I have never heard from anyone who
      has used a Dalton mag in the field. Good luck to you.
      Charles
      > The Proton Mag Forum
      > Dale,
      > I spoke to an engineer at Geometrics before I bought a used Geometrics
      > mag. During that conversation, he told me that the best liquid was
      > "Wizard" charcoal lighter. I think this was mentioned in a much earlier
      > post by me.
      > Dalton is an interesting individual as I'm sure anyone that speaks to
      > him will agree. However, if you have any conversations with anyone else
      > in the business of manufacturing mags, they all laugh at his mag. I
      > should note that Dalton feels the same about the other mags on the
      > market.
      > The low end mags out there are Dalton's and Fishers mags. Dalton's
      > being the least expensive. Then there are the high end mags that are
      > used by oil and mining companies. The prices on these units usually
      > begin at $20k.
      > There must be a difference in the low end to high end mags or there
      > would not be a market for them.
      > If I were you, and before I invested in one of the low end mags, I would
      > not buy one until I spoke to a couple of people that own and have
      > successfully used them. It is not uncommon to see a used Fisher unit on
      > the market. I have yet to see one of Dalton's units, but doubt that he
      > has sold as many of them.
      > You might take a look at Jim Koehler's site
      > (http://www.diamondjim.bc.ca/ppm.htm) and look over what he has done.
      > Jim has been kind enough to share all of his work by placing it on his
      > web page. Once you download the files, you will get an idea just on how
      > much time Jim has put into this. I do not think that this is a project
      > for the electronically disadvantaged (like me), unless you find someone
      > to help you. Jim's plans sound like they will fir your needs, where I
      > would likely have to make some adaptations to use it for finding sunken
      > wrecks. If you do not have an electronic background, you might have to
      > do what I have done ... ask your friends for help, or ask them if they
      > know anyone that has an electronics background that may be able to help
      > you build one. It would be much less expensive and you would learn
      > something in the process. If you read Jim's material, he will supply
      > some of the components needed at a very, very reasonable price (cheap).
      > In Jim's most recent e-mail he had mentioned that he updated changes he
      > has made. Maybe he could let us know how his unit is performing. Jim,
      > do you have an idea on approximately how much you unit would cost to
      > build?
      > Take care,
      > Patrick
      > Dale Seppa wrote:
      > > The Proton Mag ForumFirstly, I am this list almost under false
      > > pretenses because reading the messages it is obvious that everybody
      > > else here knows 100 to 1000 times more than me. Please bear with me.
      > > Eventually I should learn enough to at least blend in. Dalton states
      > > in his literature that he uses water (distilled) as it is the most
      > > desirable proton liquid. That info is right in front of me as I type
      > > so I AM sure of it. I think I also read there someplace that he sells
      > > a special heater so his unit can be used at sub-zero operation. It
      > > all seemed to make sense to me. But would appreciate any comments. I
      > > am interested in comments from anyone who has used the Dalton units
      > > because I simply do not have the knowledge to build one. IF I decide
      > > to buy a Dalton, he will give me some instruction and based on what I
      > > have read it looks like even someone with my limited knowledge will be
      > > able to get fair results with a short learning curve. As I write this
      > > I only have his $3.00 info packet, but it impressed me enough that I
      > > just sent the money to get his book and the UofAK phamplet about
      > > prospecting for magnetic black sand with a magnetometer. Any an all
      > > comments, advice etc., would be very welcome. I will try to read all
      > > of the past postings as well as other info that I have to see if I can
      > > get up to speed enough so you guys don't laugh me off of the
      > > list. Thanks to all for your past efforts which make very interesting
      > > reading. Hope to get to know some of you over the net if not
      > > possible to ever meet in person. I am VERY interested in using mags,
      > > metal detectors, etc., as prospecting tools for sulfides, oxides,
      > > placer gold, etc. If anyone shares these rather narrow interests
      > > please drop me an email. Best regards, Dale (The name is male in
      > > case any of you, as am I, are from the Dale Evans era which
      > > interjected so much confusion for guys names Dale) [email protected]
      > > 103 North Sixth Avenue
      > > Virginia, MN 55792 USA
        Awesome scubaman!
