Whites Classic, II, III, ID, and IDX Modifications
    Originally posted by Dickie View Post
    Amazing, thank you Mr Bill!
    Could anyone who has successfully completed this mod, post some pictures which mark all the relevant components (resistors, etc) which need changing over.
    I know this is a big ask, but I would be sooooooooooo grateful!!
    Thank you in advance
    you dont need the pictures really all the components are numbered on the board and the pictures you need are all ready on the the forum i did the mod with the numbers and then found the pictures
      I just finished it and it works great! Thanks Mr.Bill for all the help and info. I'm a complete rookie at this stuff but with all the help from reading on this forum I was able to get it done.
      Thanks again to all,
      Coin
ID:	335630Click image for larger version
ID:	335631Click image for larger version
ID:	335632Click image for larger version
ID:	335633Click image for larger version
ID:	335634Click image for larger version
ID:	335635Click image for larger version
ID:	335636Click image for larger version
ID:	335637Click image for larger version
ID:	335638Click image for larger version
        Missed one pic!!!
          Mr.Bill
          If I could trouble you with a quick question. Do these instructions pertain to the IDX PRO as well. Any difference at all.
          Thanks.
            thankyou
            Originally posted by Coin Chaser View Post
            Missed one pic!!!
            [ATTACH]24147[/ATTACH]
            Hi Coin Chaser,
            Great work and just wanted to say thanks for sharing.
            Did you just use a normal drill for the knob holes?
            Rich
              Yep, But I used a step bit.
                three months ago I picked up a Classic SL/ID up at a local pawn shop, then found a Mr. Bill modded IDX-Pro on craigslist. So now I'm in the process of modding my Classic. I've done the pots, now need to do the resistors.
                  Oh yeah, what is S.A.T.?
                    nevermind... :-)
                      So what exactly is the "boost circuit" Bill advertised? I understand the external GB and Threshold and all, but is the replacement of a couple resistor values the extent of the work needed along with the addition of a couple pots?
                        will this mod work with the xlt ?
                        the part for more depth ?
                          Can anyone upload PCB for IDX-PRO SMD.
                            Can anyone tell me what SAT means?
                            I am very interested in modification of classic 3 sl
                            My detector was made in 2002 in the UK.
                            Labeled on the inside battery compartment
                            Thanks, I'm Theo from the Netherlands.
                              Heres an IDX - this version had a short highlighted in red.
                              Useful reference point
Name:	IDX board - with short.jpg
                              S
                                Some of these kits, the pcb, the parts, the silkscreen dont correlate perfectly.
                                Here is a look at IDX and what I built.
Name:	IDX IDENTIFIERS.jpg
                                S
