Minelab Etrac/Explorer li ion power system
  • Minelab Etrac/Explorer li ion power system
    Ok, now I woud like to study this mod.
    I would like to maintain the original battery holder and add in some lighter and powerful li-ion batteries.
    What about 3 18650 cells (unprotected) with 11.1V PCB? The only problem is that with a diameter of 18mm will be hard to get them fit in the holder.
    Something like this:
    Any other idea?
    Thank You.
    Ok,
    I made some progresses with my experiment.
    I created the base to place my three 18650, get the PCB delivered, made the contacts (to the detector) and mounted them temporarely.
    To gain space I had to cut the base and insert batteries...
    I will add some balancing wire following the scheme I found on this forum.
    I guess that wires that go to balancing will be soldered to the PCB, any can confirm?
    I will use an IMAX b6 to balance/charging the pack...
      Ok. Mission accomplished.
      I connected PCB to the batteries following the (PCB) producer scheme and balance leads to the batteries following the above scheme I found on this forum.
      It fits well and works flawlessy. Now I have a nominal 3400 (mah) li ion system for my FBS detectors...
      Here are some shots:
      Battery pack finished
      Contacts
      It fits well and stay in place. In this shot my Expl II is turned on. I removed the battery cap just to not brake it during my tests...but now it is in place.
      During charge on a IMAX B6AC
      Cells balancing
        Thats a handy modification, how much longer do you expect out of the batterys?
        I got the Quattro same battery set up as yours
          Hi,I do not know how many mah my FBS absorb, but I guess not less than 30 h with headphones.
