Is there a Modification to separate the battery from the audio headphone jack on the Relic Hawk???
  • Is there a Modification to separate the battery from the audio headphone jack on the Relic Hawk???
    ....just wondering!!....Never saw the battery connected to the audio headphone jack before??...Heard that there might be a Modification to separate the two??.....Or would you leave it alone and keep it in the original configuration??...Also does anyone know where I can get a connector like the one used on the original Minelab Relic Hawk??....It is a 6 pin Military spec. type connector. I assume that these are hard to find!!......or would it just be easier to take an existing connector from a coil that I already have and just make an adapter that would fit a more common type connector??....just some ideas.....would appreciate any comments ....Pro or Con.....Thanks Joe
