A while back I acquired a Spectrum XLT. It is surely going to keep me busy in learning mode. One thing I find annoying is that when you want to experiment with setting changes you don't seem to be able to change the setting in realtime to test for results. Instead you change the setting and toggle the finger switch (right?) to make the change and.. poof.. you're out of the Menu you were in. Do newer Whites models work this same way? Imagine a guitar amp working this way... aarggh. Am I missing something or is this the way it has to work? Is it a hardware limitation of some sort?
Spectrum XLT realtime variable adjust?
I also noticed one funny thing, older Spectrum (not XLT) seems performs some functions a bit faster than newer XLT model!?
Or it was just my imagination?
After switching on newer one, the XLT, i remember i was annoyed too with it's slow responses when manipulating through onscreen functions.
Originally posted by bklein View PostA while back I acquired a Spectrum XLT. It is surely going to keep me busy in learning mode. One thing I find annoying is that when you want to experiment with setting changes you don't seem to be able to change the setting in realtime to test for results. Instead you change the setting and toggle the finger switch (right?) to make the change and.. poof.. you're out of the Menu you were in. Do newer Whites models work this same way? Imagine a guitar amp working this way... aarggh. Am I missing something or is this the way it has to work? Is it a hardware limitation of some sort?
Originally posted by ivconic View PostI also noticed one funny thing, older Spectrum (not XLT) seems performs some functions a bit faster than newer XLT model!?
Originally posted by Carl-NC View PostNo, all the same speed.
Yes, maybe are XLT displays bit more inert than, when refreshing?
Don't know what was and why, but i am almost sure i saw more inert and slower display behavior then the one on older Spectrum on which i was much used on.
Or... maybe there was some electronics problem at that particular XLT model.
Similar i experienced later when switched from Exlporer XS to SE.
