Minelab GPX Handle Switch and Cable
  • Minelab GPX Handle Switch and Cable
    my cable is broked ,
    i need quick track connector with cable,
    i think binder 709 series connector,
    • Mfr. Part No.79-9002-12-03
    is it right ?
    Hi Ademadem
    I just compared it with my cable. It appears to be the same except my cable does not have the rings in the molded rubber body. That area is approximately 10 mm diameter instead of the 9 mm in the data sheet. This dimension is is not important it is probably just a different manufacturer. I have repaired two of these with Marine heat shrink tubing which has a glue inside that really grips the wires and cable.
    Minelab will not sell the cable without the handle assembly which is $128.00. My first cable was broken under the 3 year warranty so they just shipped me the handle and cable free.
    Have a good day,
    Chet
