modification ATX
I realise this thread is a bit old, but I'v been digging recently in old ATX and have some data that could be useful to you guys.
The stock 12"DD coil has the following parameters;
TX 270uH, 700mOhms with the cable.
RX 540 Uh, 12 Ohms with the cable.
The coil cable is with two pairs individually twisted and screened together. No screen between TX and RX part of the cable. The TX cable wires are about 0.6mm square, the RX cable wires are very thin.
The RX loop is balanced perfectly. If the RX loop is out of balance the Iron Check does not work properly and probably the discrimination too.
The 20" x 15" ATX mono is build with a RX pick up coil that is stuck on top of the TX loop. The RX pick up loop is of thin magnet wire. The TX loop is Litz. The electrical parameters are the same as of the 12"DD.
The RX pick up loop is controlled by a switching smd board (placed in the coil) that takes the TX pulses and trough a switching schematic done with mosfet transistors and no added power supply. The switching board is connecting the RX pick up loop (only when the TX loop is switched off) to analogue ground and the input of the detector like the RX on the 12"DD.
The reason for this is because the TX of the ATX is a self regenerating type (this is what it looks like to me) or a sort of a pseudo resonance of sorts and it can not function properly if any inductive load is opposing the TX loop.
The TX loop in the ATX has no reference to analogue (signal) ground or minus of the battery therefore standard Mono coils can never work. The ATX requires a separate RX loop to function properly.
I never had the time to trace the schematic of this detector. So if anyone else has I will appreciate if they would be willing to share it here. I'm just curious of how this thing works.
