This mod has been done at the factory on all SL's made since 2015. So, only applies to earlier models (mine is 2013). It consists of removing the diodes D20, and D21, and capacitor C56. You also have to install a jumper across two of the three diode leads on D21. I'll post a pic showing what I did.
The effects of this mod are much more subtle than the sweep speed mod. Maybe a 5-8% gain in sensitivity in the air test on the 1 grain gold bar. But, still some gain, though I had to be paying attention to hear it.
Getting the jumper in place is tough...took me 15 minutes of fooling around to get it soldered in. I'm an old Air Force radar tech, and don't have the skills for this tiny work. Not to mention the fingers of a 40 year concrete construction guy...LOL The mod pushed my air test distance on the 1 grainer to 3 1/4", without headphones. Might have done a bit better using the hp's. there is also a slight increase in ground noise to contend with, but nothing that really bothered me. In really ugly ground, it may be worse. We'll see. In the pic, the red triangles are where the diodes were. On D21, you can see the jumper under the lowest leg of the triangle. That jumper is 3/16" long. The straight red line, on the right, is where C56 was located.
