Hey guys, I'm a newbie in electronics and I need some help.
Although I'm just getting the hang of it, I need some help to understand how a mosfet affects the pulses on a coil.
For example I have IRF840 which has an output power of 125W and Maximum Drain Current 8A, If I replace it with 30N50 for example that has an output power of 300W and Maximum Drain Current 30A, how will it affect the coil (at least 1.5mm core thickness)?
And another question, Is there a way that I can separate the transmitter and receiver coil and if so, what modifications would be needed?
I have a Clone PI-W and I would like to separate the Transmitter and Receiver in two different coils, is it even possible?
TL;DR: If I replace IRF840 with 30N50, what would the advert effects be, if any? Can I split the Tx/Rx of a PI metal detector in two loops?
Thank you guys for your time, any help would be much appreciated!
