Tesoro Eldorado SAT
  • Tesoro Eldorado SAT
    Can the SAT speed on the Tesoro Eldorado (uMax type) be adjusted or changed? I would like to increase the speed.
    i grasp you mean ALL-METAL-MODE with knob in position AUTO. or not?
    can you send pics of eldo to me?
      The Tesoro Eldorado (uMax) SAT is always on in All Metal mode. All Metal is a threshold based, motion mode. SAT does not have any external switches or pots, preset at factory. I wanted to speed up the SAT with an internal adjustment or component swap.
        ok. are you ready to solder SMT components? those are not so small, 0806 type perhaps.
        are you ready to open housing and see a hank of wires, you must desolder them?
        what your level in electronics? 88 or 14?
          Replacing a component on an analog pcb isn't rocket science, I thought someone that has done it could point out the correct internal pot to adjust or controlling component to change out, along with a little diy advise. I have done many internal mods on other Tesoro Factory built units, it's not difficult, if someone shows you what to do.
