Surf PI efficient and simple speaker driver for low impedance speakers.
  • Surf PI efficient and simple speaker driver for low impedance speakers.
    Hi!
    This circuit based on comparator so it produces well sharp shaped pulses at the output and drive low impedance speakers. In this video i drive a cheap 6 Ohm speaker with aditional 47 Ohm resistance.
    circuit
Name:	Surf PI speaker driver.jpg
    video
    https://youtu.be/ZKQLycUPBV4
    Ready for comments, critic and tomatoes.
    nice, but the schematic is a bit confusing, c1815, a1270, bc548, bc557 and mpsa 13 are all mentioned but which did you use?.
    as for the mpsa13 i have found that mpsa14 is easier to find and has more gain, the mpsa13/14 is a good replacement for some darlington paired transistors too.
      Hi Sinclairuser!
      Yes, i redrawn circuit. I use two C1815 and a1270. I just have this transistors and last one is power related for load driving purpouse. Thanks for your knowledge, last time i combined two transistor to make a darlington pair and had better results than with mpsa13, for next time will look for msa14.
      Heres the circuit.
Name:	Surf PI efficient speaker driver_circuit.png
        Some minor corrections for circuit and SMD layout
Name:	Surf PI efficient speaker driver_circuit_v0.2.png
        Smd 15x15mm PCB
        SurfPI_speaker_driver_SMD_PCB.zip
          thanks vadim18 for clearing that up, nice simple mods like this can make all the difference sometimes.
            Well, 2 years after i find what the problem is.... that's all about DC component during transitions, thats why Surfmaster work well only with piezo
            Click image for larger version  Name:	Transient__SurfMaster_Original_Speaker_Driver.png Views:	0 Size:	84.0 KB ID:	413671
              Here is alternative solution with some small bonus and simulation
              If anyone interested in microcap sourses i attached all in zip file ​
              Click image for larger version  Name:	SurfMaster_PI_Speaker_driver_Modified+Knee_Control.png Views:	0 Size:	130.0 KB ID:	413675
                Here is link to Micro-Cap on web archive https://archive.org/details/mc12cd_202110
