Whites TDI : Pots & switchs values/position
  • #31
    If I understood correctly, a 19 cm gold ring, a 2 cm euro coin. you may have a problem with the GB.
    • #32
      Originally posted by Melano87 View Post
      For a one euro coin, the TDI SL took it at 30cm, my TDI modified at 2 cm (not 20 but 2)...........
      Are you sure the GB is turned off?
      • #33
        Yes, the "GB OFF Fine" is OFF and the "COARSE GEB" in the mini. For the gain if I increase I see the increase in the distance with my gold alliance, no change on the euro coin. A succinct wiring diagram by hand of my GB.
        https://zupimages.net/up/23/02/aylu.jpeg
        • #34
          Hi Carl,
          I tried many things, and the Pulse Scan improved by putting an On-Off switch on the GB and a general GB potentiometer rather than the GEB On-Off Fine (resistance) + Coarse assembly.
          On the other hand I still have a "power" problem, it does not take targets at more than 10cm, when I turn the Gain potentiometer I see the slight evolution but nothing more.
          Thanks.
          • #35
            It will take a deep dive into the circuitry to figure this out. Do you have:
            1. A good understanding of how PI operates
            2. An oscilloscope
            • #36
              Ok, thanks Carl.
