Garrett GTI 2500 coil solution !
  • Garrett GTI 2500 coil solution !
    Finally solution...
    Scorcher (non imaging) coil. Cable consist of 3 coaxial,red stripe coaxial,blue stripe coaxial, and pure white coaxial,also 1 single green....Well, red is RX,white is TX and blue not used in this case.I guess reserved for imaging coils like spider.
    The green is a sort of VCC but in this case pull-uped with resistor 390 k on minus pole.Also there is one resistor of 390k(also) between rx and tx...sort of coupling....not sure...maybe bias....maybe stabilizer !? I am not sure after all..
    But most interesting thin for me is the not connected blue coaxial...they simple left it to flow inside the housing,although it is conected on the other side-on the jack leading in to aparatus. This gives me an ideas to experiment with additional
    rx coil conected to that unused points.It will need some coupling...but I'll see.
    I solved my problem.Coil works fine.I just writed this for somebody here may be
    interested....regards....Also I maked a several White's Classic III aparatus so far...But I replaced an existed lc oscillator with a quartz one based on cd 4060.
    It is working well, even better in some %. Now I am planing to extend a sound output...I would like to gain sound and to have rich poliharmonic output.Also I am very interested for the sound with a slice delay, something like sound of Fisher CZ5.....But I do not know how!!!? Any ideas.....Write me, let's exchange ideas and schematics....
