I was wondering what Mr. Bill does to boost the depth on the classics. I don't what to steal his work. I just wanted to know in general what would be done. Is it adjustments or are parts added to the circuit. As it is the two shipping charges cost 1/2 as much as the mod. I wish I lived close.
Classic boost circuit
hope thid will work
I got this from mr bill
Here’s what you do to increase the sensitivity of the Surfmaster II VLF unit.
Replace resistor #R7, that most likely is 100 ohms with one that is 51 ohms. This will drive the coil a tad bit stronger. This is off of the MPS3638A #Q1 transistor.
Go find resistor #R24, that’s connected right off the sensitivity control at the board. That resistor will most likely be 470k ohms. We want to change this to a higher value. I usually use a 2.2m ohm here, but in some cases it’s a bit on the strong side. Perhaps a little trial and error may be in order ??
This should improve your unit noticeably. Have fun.
Mr. Bill
Surfscanner Detectors
Originally posted by rcasi44 View PostI was wondering what Mr. Bill does to boost the depth on the classics. I don't what to steal his work. I just wanted to know in general what would be done. Is it adjustments or are parts added to the circuit. As it is the two shipping charges cost 1/2 as much as the mod. I wish I lived close.
Scott
