TeKnetics Mark-1 LTD Mod is complete
  • TeKnetics Mark-1 LTD Mod is complete
    I always Had a Love Hate relationship with My mark-1's I've owned. Loved
    the ATI but hated the discomfort of a Hip-Mount and having all the cords hanging while have to constantly rearange the Control housing. So I decided to do something about it. Below is the detector in various stages of the Modification.
    I first started with this unit below.
    Another Photo of the Coil Connector and Toggle Switch
    First thing i did was remove the Side Labels with a Hair dryer and a small tool to get behind the label while carefully heating the label and removing it at the same time. Then I remove all six screws from the bottom of the Detector after removing the control Knobs and pushed the control switches down while pulling on the top housing. After removing the Housing I cliped the Red & Black wires to the meter from the circuit board,leaving a half inch or so on the board so I'll know where to soldier the new wires later. The Meter itself
    will push out of the housing from the inside of the top control housing.
    Wires from the Analog meter
    I then carefully measured and cut a piece of hard Plastic and sealed it the area where I removed the meter.
    For support in the Top Red case I Epoxied a 1/10" thick piece of aluminum.
    This is needed so you don't crack the plastic case when mounting the detector to the rod assembly. You "SHOULD NOT" use the aluminum support that is holding the Potentiometers or you will break a soldier connection or Possibly break the circuit board. Also in the picture below you can see the two screws that i epoxied into the aluminum housing support after drilling two holes at the proper place.
    I then Installed another Teknetics Connector where the Toggle switch was for connecting the toggle switch and and the meter wireing from the upper rod assembly
    After installing the new connector I first soldiered the red & Black wires from the connector to the Board for the analog I.D.
    I then soldiered the other three wires from the connector to the wires That I cut when I removed the Toggle Switch. Not all wires here will be exactly color coded so you will have to make your own diagram when you do this so you won't get confused later when soldiering the male connector to the lead cable that connects to your meter toggle Rod Assembly
    From here you want to make ABSOLUTELY SHURE that the wires ar installed
    so that the top cover will install correctly. There is little clearence between the circuit board and the bottom housing so if the wires are not routed correctly on of the wires could be Pierced by a Soldiered component from the bottom of the circuit board....BE CAREFULL!!!!
    Heres a finished photo of the Control Housing. I still have to install the stickers after I have finished drilling the holes for the mounting hardware.
    I had to put it hack together so I could find the Perfect Balance spot while
    I temperarly mounted it to the rod assemble with velcro. after finding the best place to mount the rod assemble I then removed the top case and
    drilled the holes and epoxied the nuts to the top aluminum support strip.
    I didn't get any photo's of the Rod Assembly internal wiring conversion.
    But you will have to alter the meter housing for the toggle switch.
    The toggle switch still switches to the same direction for all metal and discriminate as located on the meter face. I hane include some photos below
    of the rod assembly.
    Below is how it looks when You use the detector in the regular Hip-Mount
    configuration.
    This is a Photo of the U channel where the excess Cable will be stored when
    using the mark-1 in the HandHeld configuration
    This is the finished product. I still have to get some thumb screw to replace the Phillips screw that i used to mount the control housing to the rod assembly.
    The picture below shows the rubber Bushings I used to help releive any stress that might cause any problems further down the road.
    Now Thats A MARK-1 ready for Spring!!
    That really looks like a nice detector. You did an awesome job on it. Where did you get the new housing and arm for the meter assembly?
    I just picked up a Mark 1 today that came as a hipmount originally. The battery terminals are in terrible shape though. I've broke 3 already cleaning them. Do you have any idea where I could locate battery terminals like these units have?
    Those side labels were a real pain too... I didn't have a hair dryer.
      mark-1 mod
      Eagle EYE
      The housing and rod assembly are Brand new Parts I ordered from Whites
      electronics. They are XL-pro parts. You can get new battery clips from
      Keith Wills at East Texas Metal detectors. He's also a repairman for older
      teknetics detectors
        Thumb screws are now installed
        Just plug the holes on the Housing and get the Hip_mount straps and I'm
        ready for the conventional Hip-Mount Configuration
          Mark 1 mod
          If you don't mind me asking... What did the rod and meter housing cost you and how do you order one? Its not shown on the Whites website. Thanks
            Cost
            The upper rod assembly was new whites parts and cost right at $135.00
            Call whites and tell them you want to talk to someone about purchasing parts. Tell them you want a upper rod assembly for a whites XL Pro
            without the analog meter.You will also need to order an S-rod and a Arm Cup. You should get everything but the lower fiber rod if you order like this. I already had a new
            lower rod so I didn't order one. The new rod assembly will have the upper
            control housing on it, so you will have to drill out the two rivets that secure
            the upper housing to the rod....I cant find the invoice or I would give you the part number for it. Doug
              looks nice
              Very good mod
                Mark-1 Mod
                Thanks Clondike
                heres a few more photos with another addition to the Mod. I added a Stand for the rod assembly when used as a Hip-Mount.
                  Mark-1 Mod
                  My Mark-1 Mod has found another Home!
                  Good Luck,
                  Daryl
                    Daryl I hope you enjoy that Mark-1
                    Because I'm thinking on Building another for Myself
                      Please, does anyone have the photos from this thread saved on computer? Can you upload them?
                        Mark one mod
                        Since Photo bucket messed me up I'll will have to look through all my cd's with photo's to see if I still Have them. If you haven't heard anything by the weekend shoot me an email to dwr62@msn.com
                        Doug
                          I have pictures of mine during modifying if that will help
                            Thanks guys, I'm searching around for an old unit, but these models seem very rare. The word is that they are one of the best detectors ever designed, and so am gathering all info I can, am especially interested in pcb pictures and possible mods just in case I can find one to buy. I have a schematic from this forum.
                              Dbanner
                              I was one of the Tek dealers back in those times. Yes, they are a very accurate machine, as far as target TID meter and audio Identification was concerned. But they had a large case, and were awkard in balance, that is why Doug modified it into a Hip Mount. The earlier models of manufactures had smaller cases, thus they were modified to fit right under the belly button, and touted as Belly Mounts. The Mark 1 and Mark 1 LTD, were too large to mount under the belly button, as it would be in the way when you went down to the knees to dig the target. Thus a Hip Mount or SLING IT over the arm so you could lay it down on the ground, was easier to use. If you possess the ability and expertise to make a brand new LAY file, and use SMD parts, placing them into a new smaller case, now that would be the thing to do.
                              But then you will need to have Set Up Specifications and Wave Form instructions, or at least do some dual trace Oscilloscope Readings from the existing unit so you can set up the SMD new unit fairly close.
                              Melbeta
