delta pulse
  • delta pulse
    hi to all
    i want to modificate a LCD for delta pulse
    LCD works for deepth
    or i want to modificate somewhere of delta pulse
    Does anybody has a good idea for Delta pulse_?
    What is the Best Gold Detector w/ high Depth Range ?
    Hi Ismaik :
    Hope you find alot of information about Delta Pulse ...
    are you arabic ? i think you have turkish name !
    What is the Best Gold Detector with high Depth ?
    I have found that most metal detectors in the markets were disappointing !even with new tech. they are using .
    Most M.D have depth limitations and can`t go deep more than (12 inches) !
    Carl , will you be sure about one metal/gold detector that reaches 6 - 8 meter depth with accuracy signal ?
    P.S : I am not looking or even searching for : coins, relics, nickels, or even gold nuggets !
    My whole work depends on : Ancient Treasure , Buried Gold . I am working to locate big gold treasures ( more than 10 kg ) .
    Which Detector i have to use ???
    Help Needed .... i am waiting 4 response
      [quote=Morris_jo;50868]Hi Ismaik :
      i am from turkey and now i am soldiering
      my soldierind will be finish after 5 mounth
      i am an electronic techniceer and i want to working with delta pulse
      but i want to upgrade it so looking for modificate it
      good working
