I have just completed some more mods for the SD series of detectors and these mods could also be applied to the GP series giving superior depth over the stock standard models. So far the front end mods on the SD series have been a great success with up to 30% depth improvement and near 100% sensitivity improvement on small Gold. My latest series of modifications involve modifying the output stage feedback loop to massively increase the coil voltage. This involves changing the front end switching Fets,the output fets, the voltage stabilization fet, the reservoir capacitor, both blocking diodes and load resistors. Another modification was to convert the detector to run on a higher voltage like 12 volts and thus enable up to 800 volts across the coil. These modifications can be used on the GP series as well as the SD detectors. It involves running 2 power supply rails, one to the low level stages and one to the output stage. This involves cutting the positive groundplane of the PC board and adding a few low ESR capacitors to keep the high power switching current from modulating the low level supply.
Other changes such as using Fast but soft recovery diodes around the output stage result in a much smoother threshold as demonstrated in the SD detectors that have been modified. If you are interested in the whole procedure to do these modifications then let me know as there is a bit of work in writing up and putting up photos of the various modifications.
