TL071CN replacement
  • TL071CN replacement
    hi all
    does any one know any better OPAMP than tl071cn
    thanks all
    Originally posted by metaldetector107 View Post
    hi all
    thanks all
    you can try with OP27, but much depends on where you put it.
    Kind regards,
      TL071CN
      JFET Operational Amplifier, single
      Vs:±18V Vu:200V/mV Vo:±12V Vi0:3mV
      OP270A
      Low Noise Operational Amplifier, dual
      Vs:±18V Vu:2000V/mV Vo:±13.5V f:6Mc
        Name the purpose of TL071 and we'll see. For what it's worth, it provides best bang per buck in applications where 1/f noise is an issue. So if your application uses frequencies lower than 100Hz, you'll spend a lot more for a better replacement.
          Originally posted by reza vir View Post
          TL071CN
          OP270A
          Again.... look at the date of the post before you reply. This one is also 5 years old!
            Now that this frankenpost has been brought back to life - If I wanted to upgrade a circuit, I would not necessarily try to replace the opamps with a better part. I would improve the power supply driving the opamps, and maybe the virtual ground depending on how that was done. It would depend on the schematic of course.
              It really depends on purposes and what you can pay for it!
              Sometimes it's far more advantageous to just couple a discrete higher bias current differential pair to a decent regular opamp for noise performance. Often the case with photodiode front ends.
