I have had this machine for a while now and have today finally discovered the secret to this machine....Although I have had this machine for a while I have always used it in quiet mode that is with the threshold right down on zero...and it still was a tad better than my whites GMT on sensitivity...the whites gmt when you increase threshold you lose sensitivity...But on the garrett when you increase the threshold to 10 or even maximum it becomes a real powerful VLF and it is extremely sensitive to small metals with fairly smooth threshold and when the VCO is turned on Auto GB and Auto threshold all turned on it becomes an absolutely Gem to use ...
The air test I have done are as follows..
5cents austrlian coin at 22cm max
20cents australian coin at 32cm max(20cm without any threshold)
1 dollar australian coin at 32cm max
and the small stainless washer weighing at 1/4 gram at 15 cm (awsome)
So If you dont mind operating with the threshold tone and vco on (something alot of users of this machine dont know or use)....you will gain 10cm of sensitivity....So on small gold it should be magnificent and beats the gmt easily and up there with the best of the VLF machines ....
I hope this helps somebody
