Need help. Need guidelines to locate the problem.
A man send me brand new SD2200. Looks like never used. Switching ON with coil connected, machine is producing pretty constant wobbling audio. Nothing else. Only Tone adjustment reacts, no other else. Without coil connected when switched ON it starts to act like everything normal. Treshold and Tone adjustments reacts and makes difference in audio so as Tune button when pressed (only first time after switch ON).
There are two brand new coils and machine acts the same with both coils. Battery is brand new and charged to 6.5V. Drain is small...when machine switched ON voltage on battery changes from 6.5V to 6.4V....
All connectors checked from eventual breaks or shorts - good condition (brand new).
Coil measured and seems there are 2 coils inside; 0.4 ohms and 16 ohms.
I just recorded 3 MP3 files using microphone closed to earphones. 3 cases; first one is audio when coil connected on machine. Second MP3 file is when coil connected and Tone pot turned and third one is audio when coil is not connected....
So...
Damn enclosure is so tough and all inside is packed pretty awkward - not desirable to frequently open and close. To void that i would firstly like to hear your suggestions about present issue. Hints, tips, suggestions will be highly appreciated!
There is SD2000 schematic on these forums....not useful in this case cose i already compared it with what i saw inside SD2200 - lot of differences...
Ok...
i am restless to hear suggestions and advices!
Regards!
So...
Ok...
Regards!
