golden mask 3 power mod
  • golden mask 3 power mod
    hi all i have a goldenmask 3 and have heard that you can take out the battery pod inc the rechargable batteries and solder in a standard 10 slot holder 5x5 to take normall batteries or rechargables
    the guy who told me about this uses rechargables as the voltage remains the same 12v
    will i be able to do this mod so i can use normall batteries such as duracell,s (this will give me 15v )and i am concerned this might be to much for the detector
    many thanks daz
    many thanks daz
    Depends of detector design itself. Most probably you should'nt have any problems. Yet ....better to check schematic.
    Last and most safe solution is to use 8 x 1.5V batteries. You can find 4x holder in local shops...i presume. Than buy and use 2 of them (wired in serie).
    Or you can try to trace power supply stage at that detector and to post here that part of schematic. Than you will be answered most accurately.
    Regards!
      thats great thanks
        eksperimetisao'm with DD on the probe vajts Classic with rounds of 70 and resonant Capacitor 220 receives the frequency nf 6 5khz wire thickness o.45 mm and coil ptijemni rh 250 round wire thickness 0:18 mm and resonant Capacitor 33nf. 28cm diameter probe dd. I received a range of 30 cm diameter 30puta as 170cm in air, 20mm coin as 50cm air test. Hi-Orbit.
          Can someone help me about Golden Mask 3 plus I deciphered transistors and one IC circuit on a small plate but other IC circuit is unknown to me. Small board oscillator, which is normal to have 20 V spades to pick a turbo regime 12ov spades spades . Transistors are irf530 and IRF 9530 oscillator is not done with 555th Al second round I was unknown.
