Compadre sensitivity PCB rev 4 help!!
  • Compadre sensitivity PCB rev 4 help!!
    I am posting a picture of the rev 4 pcb. I have labeled the holes at the sensitivity pot. On the schematic which points connect to which holes on the pcb? Can anyone clear this up for me? Also just curious. At the bottom of the pcb I have circled a spot that looks like a place to add something optional, maybe for another model of detector or something. Any Idea what might would go there? Or what it is for? Thanks for any info you can give me on the connection points for the sensitivity pot.
    again guys I URGENTLY AND URGENTLY ask you do the images more legible.
    please do these step by step!
    1. wait clear sunday time. the sun must be VERY OPEN!
    2. GO OUT from your home, at your homeyard, at the sunlight.
    3. place PCB so the sun light will be from left upper PCB corner.
    4. the shadows must be short, but they must be!
    5. do a photoshooting.
    6. you have NOT EVEN A TINY CHANCE here to get the answer if you are doing your Home Work poorly and woorse.
    GOOD LUCK IN THIS YOUR NEW HOBBY.
      Thanks for the instructions but I think the picture it pretty easy enough to see what I am asking. I did not take this photo nor am I a professional photographer. I was just assuming that someone on this forum may have the information I am looking for or may have a lot more knowledge of surface mount components than I do since I have practically none
        get the answer what you so want at your platform of egoism.
          http://www.findmall.com/read.php?22,...67#msg-2320067 sens mod story
