Help with coil cable
  • Help with coil cable
    Hello. I'm asking for ideas about something that is a repair rather than a mod.
    I have a Detech coil that works fine, but the black plastic cover on its cable has came off. There are 2 exposed white cables that look ok. Although it works fine I'm worried since I don't know if using it that way is right; is there a way to "recoat" this cable with some sort of plastic coating? A new cable may be the solution, but then I'd have to open coil to install it. I don't think taping it would work. Any help will be greatly appreciated!
    (I am sorry if this is not the right place to post this, Thanks!!!)
    A photo would be useful.
      Is there any way to returminate the connector?
        Here is the photo.
        The black coating is very bristle, is coming off totally.
        Thanks for your help!
          Here is the photo.
          thinking you may use a thermo cambric as we know it in our world part, in english I am not able describe this matter... it is a coating shrinking from an heating... i hope people with good english will give you an right direction.
            oops! found a text, like this
            This heat-shrinkable tube offers a perfect water-proof seal upon shrinking, due to the unique combination of the crosslinked outer wall and the thermoplastic adhesive, which will flow to seal and encapsulate and splices. Specially used for Satellite Receivers.
            ONLY AVAILABLE IN BLACK
            Standard length: 1.20 m
            Specifications:
            Polyolefin, adhesive lined flexible tubing
            Type: PLDW100 (MIL-I-23053/4 class 3)
            Shrink ratio: 3:1
            Shrink temperature: >115°C
            Operating temperature: -55°C to +85°C
            Dielectric strength: 15 kV / mm
            CADMIUM FREE - SELF EXTINGUISHING
            diam. before krimp: 9.0 mm
            diam. after krimp: 3.0 mm
              Hi, kt315. Thanks, that is VERY interesting, now I need to find a distributor here in the states...it looks exactly what I need.
              Only minor thing to it I will need to take the connector off in order to feed cable to the tubing, I hope I can do that!
              Thanks!
                Heat Shrink become quite stiff after applied.
                I would us a vinyl sleeve and apply the shrink to the ends only!
                Be sure to use the type that has adhesive within.
                http://cableorganizer.com/heat-shrink/
                  A solution I've used, in the past, is to simply cut the cable a few inches from the coil (your photo shows the cable is ok at that point) and put in a new section up to the socket. Then use heat shrink sleeving only on the repair joint.
                    You might try the stuff to coat pliers and other tool handles. you could dip small parts of the cable at a time.
                      I think that is the route I would go Too!
                      Just be sure to use the same wire gauge and type if you can.
                        Thanks to all for your suggestions.
                          But how does he fix rug????
                          Ok, slow day . Sorry!
                            No problemo, Simon, everyone knows that schools for slow people gotta be boring to death.
                            By the way, nice pink Crayolas you've won today!
                              Just stick some small diameter spriloom over it or small diameter split loom.as in cable Hifi.will then look still neat an slim,an ok!an cost little!
