Hi there Mick,
I have tested the machine in two different setups:
First, when I connect the coil and turn it off, that is BUK455 FETS off, I have about 4 volts peak2peak noise on output.
Second, when connect input to preamp to +Batt, and BUK455 FETs off, no difference coil connected or removed, noise on output comes within 400mV P2P. Turnning the coil on in this case (I have used wire for connection between coil receive and input of front end so I can connect input of front end to +Bat while the coil is in service) increases the noise a bit.
I measure output on base of BC857 before 100k res, pin 6 of TL061 in Audio CCT.
In both cases, removing 4066 analogue switch of Ground Balance reduces the noise and putting it in place increases the noise amplitude and turning the GB pots has just transient effects and nearly no steady state effect on output.
Frequency of noise is random but in order of 1~2 Hz.
Mick, if yellow wire in transmit CCT is receive wire so what are the red and balck ones?
Another question, should the ground plane be connected to +BAT?
