Hi Mario,
Fet 11 is used for the -5v regulator, I'd leave it alone at this stage. Maybe later
The input n fet could be changed for a tn2404kl, just make sure you have the pinout correct. You could also have a look on farnells (element14) for a 200v n channel fet, low resistance low capacitance use the tn2404kl datasheet for the benchmark and don't discount the surface mount components as you can hook them up with old resistor leads.
Anyways getting nagged to go shopping
so I will put a bit more down later.
Cheers Mick
Cheers Mick
