The front-panel label is made up of many layers.You need to make sure you are peeling them all off, and not seperating the button membrane. They only need peeling back a small amount, just enough to get a cross-head screwdriver in. With the screws removed the bottom edge comes away, the two clips on the top edge seperating easily. The case can be easily fixed back together with adhesive tape on the bottom edge while you experiment.
